MochiCraft35Fly
Hello all,
I have searched the forum for threads descrbing similar problem as we are experiencing, but havent found something similar. I apologize in advance I have missed a relevant thread.
The boat in question is ACM 38 Excellence, twin D4-260B with HS63VE , reverse gearbox.
The issue we are expereincing, as described in`title, is that starboard engine or rather gearbox doesnt engage in reverse, while it engages in forward just fine.
Here is what we know for fact:
1. Issue started appearing last year, occasinaly, only when engine/gearbox was warm. Next day, when starting the engine, everzthing would be fine
2. We changed the solenoid valve on the reverse control link, but the problem persisted
3. We ruled out the Control level issue, or PCU issue by reconnecting cables from starboard to port engine PCU
4. We tested voltage on the reverse gear control link to find out it changes once control level engages into reverse
5. We also tested engagement of the control link by leaving spare solenoid` connected to the control link, while outside gearbox housing, to find that it opens as it should.
The conclusion is that the root cause of this issue is the gearbox itself and not electronics of the EVC system.
The mechanic suggests taking apart the gearbox, the control housing to be exact, but would like to better understand how mechanics of the gear engagement work before I go forward with any additinal guess work.
A manual for HS63VE would be highly appreciated as I dont have one.
Thanks in advance.
Thanks in advance.
