gear lever extension
bamspm
10 Aug 2006
Crouch
Does anyone have experience of fitting an extension lever to the gear lever on a 5hp outboard, in my case a Suzuki?
The outboard is mounted on a lifting bracket which means it is some distance outboard from the transom and with a stern locker the lever is difficult to reach. It is even more difficult to steer at the same time especially when approaching a tight berth.
I thought of trying to adapt a tiller extension but wondered if anyone had found a simpler solution
Brian M
StanFolds
8 Oct 2006
Norfolk UK
I have a 9 inch length of 1 inch diameter plastic tube shoved over my gear lever, works a treat. I think Lake Sailer has some pictures of a simlar systen somewhere.
Stan
Lakesailor
15 Feb 2005
Near Here
I do indeed. A bit of alloy bar, a couple of s/s bolts and Bob's your Uncle. It changes the gearchange from clunky to smooth and controllable in one fell swoop. Much recommended.
bamspm
10 Aug 2006
Crouch
Both are great suggestions, thanks, but it is still a long stretch facing in the wrong direction at a time when steering is critical. Possibly the 1 inch tube with a 90 degree bend extending towards the cockpit would be an answer.
Gunfleet
1 Jan 2002
Orwell
I know, a foot bigger than a wayfarer... but it is a practical solution and you can get very neat remote controls. I have had a boat with a tiller, lazarette and outboard and know what the problem is. SOmetimes manouevering you feel as if an extending arm would help. But you'd never get shirts to fit from then on.
Lakesailor
15 Feb 2005
Near Here
The next part of my cunning plan which I never got around to (didn't need it) was to make a horizontal rod on a ball-joint or a simple clevis pin and supported at the pushpit end with a loop or bullseye fairlead or similar.
bamspm
10 Aug 2006
Crouch
Yes, just what I was hoping for, out with the tools. Thanks everyone, I knew I could rely on the forum to find me a solution
