gas water heater
johnsams
New Member
24 Apr 2007
Anyone know who may stock spares for a Rinnai REU-56ES water heater.
Mine "popped" over the winter even though I drained it,must have been water left inside.
When I have checked the heat exchanger has been repaired before.
Just thought I would check before investing in a complete new unit which is now the REU-58E .
Unless anyone can recommend a different one.
Cheers
Hi ceejay 2, I had a similar problem with a Palermo but found the leak and soldered it and it worked OK after that.
Galeus
The previous owner of my boat had repaired the heat exchanger with some sort of plastic filler. I took the unit to a car radiator repairer who chemically cleaned and soldered it for a few quid. Worked fine for the last two seasons.
