Tintin
In my gas locker in addition to the regulator valve there is a valve that joins from the flexible hose to the copper gas pipe (compression joint) work to the stove.
The thumbscrew has been stiff for a few seasons but a few nights ago it snapped off, thankfully open so i can still cook. I can still isolate the gas suply at the regulator and at another valve just inside.
I found a number for a marine gas fitter in Falmouth (where I'm moored) but there is no answer.
So I'm wonderring how hard can replacing this be?
Gas ptfe, washing up liquid to check for leaks, cut back the rubber hose so it is mating on a fresh bit.
Thoughts?
Thoughts?
