Ian_Rob
Two of three burners on the hob of our Eno cooker have a much reduced flame. The third burns as normal.
Is there a likely explanation?
Thank you.
Thank you.
Blocked jets. Remove and cleanTwo of three burners on the hob of our Eno cooker have a much reduced flame. The third burns as normal.
Thank you.
I've used nylon bristles, such as from tooth brushes to clean jets. Do still need to be careful though.yep blocked jets etc. give a good clean.
Just dont go sticking things in the jets or holes. use a proper cleaner.
Carbon and rust off the burners can drop in to the jets. Unscrew them and blow them through. Clean up the burner whilst you are at it. A vacuum cleaner is handy once you have the jet outThanks for the advice. We tried washing them throughly in warm, soapy water but it made no difference. I will see what proprietary cleaners are available.
We first noticed a reduction in the flame size of one of the affected burners after a particular rough passage through the overfalls of St Albans Head at the end of last season…..?
