Gas/grill query
Caladh
25 Oct 2009
Out there again and no longer dreaming
The grill on my elderly gas cooker flares when I light it and will go out. The gas get cut off ok. I try it again and turn the gas down a little and then eventually it is ok and can be put back to full - the toast can be cooked ! The cooker and 2 x burners function just fine. Is there anything I can clean up on the grill ? I can't locate a jet anywhere although I guess there must be one. The actual grill burner tube looks hardly used.
The other common issue is that there is a metal strip just below the flame holes that leaks enough gas to give a little flame all along to prevent the main flames lifting off. I had to replace my grill because the supply to the plate was blocked.
