fudge
Active Member
I have a recently installed gas oven with an 8mm outside diameter tail. The supply to it is by means of a quarter inch copper tube with an armoured hose and a drop fan stopcock. The final connection to the oven is made by a quarter inch to 8mm compression fitting.
The drop fan stopcock has failed and I would now like to replace the entire supply system with 8mm copper pipe and the associated fittings. I have successfully sourced all the items required with the exception of the armoured hose. Does anyone know where I can purchase a one metre length of armoured hose with 8mm tails?
