garmin gpssmap451 to Nasa ais engine
ghostlymoron
9 Apr 2005
Shropshire
Anyone had experience of connecting these? I've connected blues and blacks but nothing appears on the plotter. Help! The nasa is working because we can see targets when connected to a laptop.
Trundlebug
4 Jan 2007
River Trent
Make sure the Garmin - AIS port connection is set to NMEA High Speed in the settings.
Go into the set up menus in the Garmin and change it.
FWIW I had the same problem, so you're not alone.
However, if you have any other devices hooked up to the Garmin as well as the AIS (e.g. VHF, autopilot) make sure they're set to NMEA standard - they should be on a separate port. Not a problem because the Garmin has 2 ports.
[3889]
26 May 2003
Not much help from me I'm afraid but it would be good to know how you get on as I'm planning the same with a 551.
superheat6k
10 Jan 2012
South Coast
