Garmin Fishfinder 120
spv737
14 Dec 2004
UK, Northwest
Anyone got a Garmin fishfinder 120? Any comments good or bad, Is it a problem having a transom mounted transducer?
Thanks in advance
duncan
Home mid Kent - Boat @ Poole
asssuming you have a single sheet GRP hull construction don't bother to mount it on the transom - find a nice accesable spot inside the hull where it's not too thick or reinforced and 'stick it there' in a large blob of sikaflex (easy way) epoxy (very good but a pain to move) or it's own personal oil bath (over complex and unnecessary).
the fact that it's a skimmer type transducer won't matter one bit. you will loose a bit of power so don't expect brillant images of fish in 600ft of salt water!
Many manufactures web sites have fuller details.
Over the years I have used silicone, sikaflex, araldite, epoxy resin without noticing any difference between them in performance terms.
spv737
14 Dec 2004
UK, Northwest
Thanks Duncan
Any idea whats classed as "thick" as I am led to believe these seamaster hulls where well built!!
JKay
24 Jan 2005
Single skinned hulls position it and hold in place with a weight if that gives clear readings during a run on the water stick on with products mentioned above
I was going to do the oil bath jobbie but I'll try the silicone
cheers for that Duncan /forums/images/graemlins/smile.gif
Manxman
11 Mar 2003
If you do postion it for through the hull, don't forget to turn the "GAIN" up by 5-10%
duncan
to be honest I believe it works fine with any reasonable single skin.
to find a good spot you can use the follwowing trick - fill a plastic bag with water and tie off. Place bag where inside hull where you wish to 'check' and place 'ducer on top of the bag as horizontal as possible. Move around to find good signal - worth switching unit to manual gain/sensitivity to get a comparison.
Let us know how you get on!
spv737
14 Dec 2004
UK, Northwest
Unit fitted and passed its trial with flying colours, well pleased with it. Ended up getting some plumbers mate non drying putty from B&Q and bedded the transducer on that!!
