Garmin and ATONs with AIS.
Complete AIS support is apparently not a priority for Garmin - reportedly they also used to crash on receiving an AIS SART or MOB message (now fixed in a firmware update). I guess they do some basic testing with class A and B vessel messages and ignore most of the rest of the spec (which is, to be fair, voluminous).
It's not only Garmin that are having problems with AIS.
I have a Furuno NN3D plotter, it will not show MOB sart - I have been discussing this issue with Furuno for more than a year.
In the spring they finally acknowledged it to be a problem, the reason the MOB sart was filtered out was that it didn't transmit values for COG/SOG of the MOB...
It will however show ATON's but it uses the same icon as a boat/ship.
I'm still waiting for a software update...
There are four different AIS target types in addition two class A and B vessels. They have got different series of MMSI numbers.
1) Search and Rescue Transponders (970yyzzzz) aka normal SART
2) Man overboard DSC and/or AIS devices (972yyzzzz) aka personal SART
3) 406 MHz EPIRBs fitted with an AIS transmitter (974yyzzzz)
4) navigational aids (AtoNs; 99MIDaxxx)
My Raymarine i70 and Open CPN seems to display AIS data correctly :)
Don't forget SAR aircraft, and "base stations", which can also transmit their positions. Plus all the various other types of non-location message in the spec, like "DGNSS broadcast binary message", "Multiple slot binary message with Communications State", "Safety related broadcast message" and so on and so on. It's a very complicated system, and plotter manufacturers (for whom AIS is merely another feature on the list) have tended to just do the most obvious and widely-used bits. Then get caught out when real world usage expands past that.
In the ribnet posting is asked which combinations work
digital yacht class b and open CPN do.
Vesper Watchmate displays handle AtoNs, AIS SARTs, and AIS MOBs, with the proper IMO symbols and all the special fields (for example, the altitude of a SAR aircraft, or whether an AtoN is the position of an actual buoy or merely a virtual marker). The SART and MOB messages are handled specially, sounding an alarm even if the device is otherwise muted, and jumping out of any menus etc to a clear "how to get back to them" display.
I would also expect it to handle any other esoteric messages that come along, because the people who make it are dedicated to AIS and have a deep understanding of it (they also make base stations used to broadcast those AtoNs) - rather than general developers for whom AIS is just another annoying feature.
Should not be complicated to write a program that can send all types of AIS messages via NMEA to test compatibility with different AIS targets and messages :)
