Newman
Being a new (secondhand) boat owner I would appreciate any help I can get on connecting a Nasa Marine AIS Engine 3 to a Garmin 551 Chartplotter. At this moment in time I just want to set up a temporary ‘stand alone’ arrangement, then once the boat is ‘home’ I will have more time to take a closer look at perhaps ‘linking in’ some of the existing equipment.
I hasten to add that with the above equipment I also purchased a suitable VHF aerial.
The Nasa AIS has two ‘coils’ of cable. One coil consists of a twin red cable, one having a black line and being the negative. The other has an in-line fuse, being the positive.
The other coil of cable has a black outer sheath with male and female data connections at the ends. There is also an external blue cable running the entire length of this cable and is terminated in the data connections.
Being that there is a female data connection on the AIS Engine I have cut off the female end of the cable which revealed the following internal cables:
Red, Black, and a Bare (unsheathed). Plus of course the external Blue cable.
The Garmin 551 Chartplotter wiring harness offers the following cables for connection, coloured and labelled as below.
Red: PWR Power 10-32 Vdc
Black: GND Ground (power and NMEA 0183)
White: CAN High CANet H (if applicable)
Green: CAN Low CANet L (if applicable)
Brown: P1RXD NMEA 0183 port 1 Rx (in)
Blue: P1TXD NMEA 0183 port 1 Tx (out)
Orange: Acc/ON Accessory on
Yellow: ALARM Alarm low
Grey: P2TXD NMEA 0183 port 2 Tx (out)
Violet: P2RXD NMEA 0183 port 2 Rx (in)
Can anyone advise as to which cables on the AIS are connected to which cables on the chart plotter. I would hate to damage either piece of equipment.
The most convenient source of supply on the boat, for my temporary stand-alone setup for this single homeward bound trip, is a cigarette lighter socket close to the chart table. Would this be ok ?
One final thing, Could I wire the 12v supply cables for both units in parallel to a ‘cigarette lighter plug’ and sit in the car at home “discovering” my new system and putting in some waypoints etc ?. Or perhaps I should try this without the AIS connected as we don’t get much shipping passing through the middle of Kent !.
Your comments and assistance will be most appreciated
