Tottie
New Member
Hi. I'm a live aboard in Plymouth and have been advised to fit a galvanic isolator to my Twister. Does anyone have any opinions on these, either way?
If you search the forums for "galvanic isolator" you will find quite a lot of information and discussion.
http://www.ybw.com/forums/search.php?searchid=152260
Basically a GI is only necessary if your DC and AC circuits are bonded - the 12v negative connected the 240v earth - if the two systems are totally separate a GI is of no benefit.
You will on here too - post the same question in the PBO Reader to Reader section and watch......I just get different advice from so many people about what I need...
We have a CAT and fitted galvanic Isolaters one to each engine bay. The corrosion of the Annodes stopped and instead of only lasting around about a year they are still going strong after two years. We are in the Med in a Marina.
Peter
Peter
Peter
galvanic isolator - good idea, cheap. Isolation transformer pain in the a*** threw it over the side, far too picky a machine.
I don't quite get that (either time!) Peter.
Presumably you only have one shore power cable running through to the battery charger. As the GI connects into the shore cable, why would you need a GI on each engine?
Richard
Many thanks Peter
My understanding (which may be completely wrong as my testing of my GI with an ohm-meter simply served to confuse me!) is that the galvanic current, if there is any, is only a problem if it can leak to earth, which it can only do down the shorepower cable - presumably down the earth wire. The GI therefore fits into the shorepower earth cable to stop any galvanic DC voltage to earthing itself but still allow dangerous higher voltages, which would result from an AC fault, to be earthed safely.
Hi Richard,
You are spot on re the leakage from shore cable as that is where the stay curreny comes from. You will see many cable which are laying IN the water and so some residual leakage occurs + the usal leakage from Marina mains cables.
Good luck
Peter
I'm going to use my voltmeter again next time I'm on the boat to try and understand all this better!
Richard
