Matt341
Hi All,
Decided to keep the boat plugged in from now on and in the winter will have a dehumidifier on to save bringing everything home.
I have been advised that a galvanic isolator is peace of mind.
The shorepower system on the boat is simple, inlet in the cockpit locker, lead to fused switched, then to RCD then feeds to charger, sockets etc.
There is nothing wired to the boats anodes etc.
I have been told that the isolator just wires into the earth wire between the inlet and the trip switches and therefore prevents any damage to engines etc.
I assume that I could put the isolator closer to the inlet socket and therefore turn the fused switch off but the isolator would stay on even though nothing would be drawing off the system when the switch was off?
I assume an isolator will also protect against other boats plugged if they dont have an isolator? Will it work even though nothing is connected to the anodes/rigging etc.?
I hope this doesn't sound all to confusing.
Many Thanks
Ian
Many Thanks
Ian
