milfordman
My 20 year old steel ebbtide 33 has untill this year had a basic 12 volt system. The boat has two bronze sea cocks, one well forward on starboard side :- toilet outlet. The second sea cock :- sea water inlet on port side towards stern. The bronze 3 fixed bladed prop is on a Stainless Steel shaft ( 316). There are two 250mm zinc anodes one each side of the keel towards the stern, and a small zinc annode on the propshaft. I have checked my prop and sea cocks regularly and so far they have been OK, they are the originals. I have changed the prop annode approx every 2 years, and the main annodes every 4 years. So I have considered the setup to be satisfactory. The boat has so far allways been on a swinging mooring in the summer and in the boat yard during the winter, when I would have used 240 Volts for batery charging, and power tools with RCD in extention. However I Have now installed A 240 volt RCCB circuit breaker in the boat with A Stirling 20 Amp smart charger, and a Sterling Galvanic Isolator, all wired as recomended by Stirling. I fitted all this equipment early this summer and had it working in the boat yard. Now my boat is in tha Marina I was going to hook it up to the shore supply the next time I go down. The problem is I just read on the experts advice page that fitting a galvanic Isolator on a steel or aluminium boat is more complicated. Could some one advise is my setup ok, or should I do more?
A separate question I also fitted a Stirling Advanced regulator to my Lucas 70 amp Alternator, and the remote panel. When the alternator runs I can get currents as high as 140amps. the regulator seems to be doing as it is suposed, i.e. no output then ramps up to high level then ramps down when charged. The setup reads temperature of alternator and battery and regulator all rise but stay within acceptable limits. Good job I fitted the 40 mm area cables as recommened. I just don't understand how you can get 140amps out of a 70 amp Alternator?
