Gallons per hour
applejack157
19 Oct 2002
Could someone tell me how many gallons per hour a 24' sports cruiser like a Regal 242 with a Mercruiser Bravo III 5.0L will burn at a mid range cruising speed and top end. Also do you know if this boat would be ok on solent waters?
DavidP
1 Nov 2001
Southampton ,England
Hi
No problem on the solent and on good days over to the channel islands.
No idea about fuel for this one ,but i have Twin 4.3 alpha 1 on my 27 feet Searay and i burn about 10 gals an hour at around 23 mph, faster than this and it goes up to around 17 gals an hour at 40 mph
Dave.
A rough guide would be (more or less) 1 gallon a mile at cruising speed?
Rob
neale
30 May 2001
Essex Mud and Solent
Everyone will give you different answers on gph due to many factors, so to add to the confusion, my 24ft sportcruiser with single 5.0ltr does around 8gph at 20 knots rising to 15 gph at WOT which is around 30 knots.
I have taken mine from the Solent around to Essex and across the channel to France and the channel islands. Providing you have good settled forecasts and are happy with the reliability, (good to have an aux engine anyway), then fuel capacity becomes the only real obstacle.
Re: Nah, that\'s a bit thirsty
More like just under 2 mpg. Or that's what we used to get from a 23' Maxum
David2452
6 Jun 2001
London & Fambridge
Wide Open Throttle
Also, although very few 5.0L were fitted with a Bravo III ( almost exclusivley Alpha 1), if your boat has a Bravo III be aware there are corrosion issues on certain serial #'s on this drive. See mercruiser service bulletin boards.
David
<P ID="edit"><FONT SIZE=-1>Edited by David2452 on 21/10/2002 16:21 (server time).</FONT></P>
BrendanS
11 Jun 2002
Tesla in Space
Have a look at <A target="_blank" HREF=http://www.boattest.com>http://www.boattest.com</A> . Select 24' and sportscruiser (the 242 isn't listed) but you can see accurate speed and consumption figures and graphs for a variety of similar boats/engines. The graphs are very illuminating, showing clearly the very narrow range of speeds where boats are most fuel efficient
