fluffc
Hi All,
I am wanting to add a pump to my galley sink drain, primarily because the sink is only just above the waterline and drains quite slowly. Also, want to take the opportunity to add a bilge pump to the middle bilge.
Has anyone any opinions on draining the galley sink into the bilge, and then pumping it out - either with an automatic bilge pump or a hand pump. I assume that I'll need to use a diaphram pump to cope with 'solids'.
The boat is ferro-cement, so not too worried about galley water coming into contact with the hull.
Would I need to somehow seal the bilge to prevent smells, or do people find it stays fairly sweet?
Any thoughts appreciated
