whiteoaks7
After the voyage through the french canals we put the mast back up and reconnected the radar. I'd cut the cable in UK and remade it by solder for the small cores, crimp for the power and 50ohm BNC for the coax. It doesnt work - all I get is 'No bearing' and 'No heading' legends which are supposed to indicate a cable fault!! However, the only sign of life in the head is the cooling fan, otherwise nothing - the antenna doesn't rotate! The heater voltage is correct (this being the only other thing a user can check). The obvious thought in my mind was damage or some infestation inside the radome, but I'd sealed it and it was immaculate inside. This is seriously spoiling a warm sunny day; so... any ideas?
