rotrax
We have a serious heavy Motorsailer. It sails like a brick in light winds with the OE rig of in mast furling main and Hoyt Boom self tacking jib. Following the post by Laminar Flow who seriously improved his Colvic by increasing the SA/D I have added a Code Zero on an additional furler. I used a secondhand but good Facnor furler on a new forestay. I used 26 metres of 8mm braid on braid as furling line, the drum end thinned for three metres by removing the core.
It is too long! It builds up on the drum and causes friction. It is a big sail, about 175%, and requires lots of turns to wind it all in.
Do you think 6mm would be strong enough as a furling line or must I use dyneema?
Anyone with similar experience. We are a relitivly weak crew, both mid/late 70's but have a power winch for most sail control. Only Port side Outhaul/sheeting of the Code Zero is by a manual Lewmar 45. The Code Zero does work very well and will only be used in light conditions.
Will 6mm Braid on Braid be strong enough"
