single
What is the best way to lubricate my furling headsail.Its very stiff so is it the bearings or something else?
This may be an indication of a serious problem. Worth a careful investigation including a look at the forestay if there is ANY doubt.
I have seen a unit where a frozen top swivel was causing the forestay wire to twist.
So it deserves more than a spray of WD 40 and crossed fingers.
We a had similar problem with our Plastimo 809s furling gear.At the end of last year it became very stiff to the point of someone having to go forward and manually turn the drum to get the sail furled.Had a good look at top swivel and forestay,all good so problem was with the drum.Tried the boiling water trick but the drum looked to be pretty well sealed with no apparent means of lubricating whatever type of bearing was inside so this made no difference.Nothing on internet about diagrams for the 809s as its so old (1989 vintage) but plenty for the newer types.Bit the bullet and dismantled drum as far as possible with it insitu then poured boiling water over it and a good soaking in GT85.More boiling water poured on and then another good soaking with spray silicon.After putting it all back together we were well chuffed to find its furling action was finger light.Not bad for a 24 year old bit of kit.So dismantle yours as far as you can and give it a good clean and hopefully it should be better.
