Burnham Bob
a friend of mne has a furling headsail and a recently installed/assembled foil fitted by the boatyard. we got the headsail up no problem. he then took it down for some reason and when we came to raise it again it went up fine then stopped with a clunk at one of the joins in the foil near the top.
this we were told - when we questioned the rigger and the boatyard - was due to a fault in the sail and that the bolt rope end would need to be encapsulated by a sail maker. this seems curious as it went up last time and goes through all the joins except the last one. in our ignorance we assumed that the foil had somehow shifted and got out of alignment but we are assured it's the sail.
i did try flattening the bolt rope end with a pair of pliers but that seemed to make no difference. should we believe them that it's the sail?
