30boat
N/A
Following my previous post on how to check a VHF antenna I went down to the boat and tested my two sets with my VSWR set.The Sailor gave a 25 and 1 W power measurement and a SWR a lot below 2 so that's good.The Simrad R68 gave less than 0.5W and I couldn't measure the SWR because there was not enough power to calibrate the meter but since the antenna worked well with the Sailor l I'm OK with that.
What's amazing is that when I did a radio check both radios were picked up perfectly by a shore station 12m away.Their aerial is very tall so that partially explains it but I still find it odd.
The R68 displays a little "ANT" sign wich means there's something wrong with the output.
Can somebody explain how this can be?
