Gordonmc
I am getting round to changing the mild steel diesel tanks and am looking for some pointers on the pros and cons... and even legal/safety requirements for the outlets.
Two tanks of approx. 60 litres are enclosed either side of the cockpit with pipes joined by a junction upstream of the only seperator/filter. Both outlets are at the bottom of the tank. Each tank also has a sludge trap and drain on the floor.
All of the off-the-shelf plastic tanks I have seen so far have all the outlets, breathers and returns going through the top with no drain or sludge trap.
Is there a logic to this?
I can't see how it helps avoid a spill if there is a leak in the pipework as the fuel will syphon.
I am trying to avoid extensive re-plumbing but it looks as though the only way to keep the existing set up is to have stainless tanks made bespoke and use the existing fittings.
Any thoughts?
Any thoughts?
