gavin400
I presently have a gravity fed fuel system whereby the fuel outlet consists of a female threaded outlet welded to the tank, into which is screwed a shut off valve, then the copper pipe to the filter/engine.
Although the tank has a small sump with drain valve, the present arrangement effectively means that the fuel is drawn right from the bottom of the tank.
I want to install a length of copper pipe to extend say 50mm above the bottom of the tank.
The question is - what sort of fitting do I need in order to achieve this?, I'm effectively wanting to form a seal to the base of the tank at mid point on a short length of copper pipe
I'm sure its a simple, standard fitting but I have looked at BES and can't find what I'm picturing in my mind.
If the above makes any sense, all help gratefully appreciated!
