Cornishmuttley
My plastic (or similar) diesel tank has a breather tube that had no 'end', it just had a loop with the top end tied to the underside of the cockpit coaming (like that when I bought the boat). SWMBO does not like the smell of diesel which now permeates the boat (until aired through) and wants some action to resolve the problem. Actually the smell does get a bit much. In addition to blocking up holes forward from the aft locker, should I:
1. clamp the end to stop fumes (or will this choke the engine)
2. drill a hole in the cockpit and fit a two way valve of some sort (least preferred option)
3. some other solution that I hope you will come up with ('scuse the poor grammar)
I have not seen a breather on other tanks and am wondering if it really is necessary.
