The Dogs Pollacks Brother
Bora Da from sunny...but windy...Wales everyone.
Well the electrics have been completely re-wired now so on to the next job.
I am upgrading the fuel system on the Grumpy Uncle and contemplating fitting one of the new solid state electric fuel pumps in the line.
Currently it is like this......fuel tank----CAV type filter with primer pump------mechanical lift pump------engine mounted CAV type filter---------injection pump.
I am just wondering if I should leave the mechanical lift pump in the line, or do away with it completely? It does work, but its the origional on an old BMC 1.5 so is looking old and tatty. My thoughts behind taking it out of the line are simply it will be 2 less joints in the fuel line to worry about.
If I leave it in, I guess I could wire the pump so that it is switched manualy as and when I need it......e.g, bleeding, at start up (I read they can assist starting?) or purely as an emergency.
My early thoughts on the new system are to set it up as follows........fuel tank------electric pump-----new double CAV filter assembly (with glass water seps on each filter)------injection pump.
So in essence, I still have the two filters but they are in one unit and the whole thing will be fed by a 12v pump.
Any thoughts or pointers greatly recieved as usual guys n gals
Jeff.
Jeff.
