Yorkshire Exile
There are two hoses running between my plastic diesel tank and the engine. One has a stop valve fitted and i assume that is fuel out and the other has no valve apart from a connecter half way (a non-retrun valve?) and i assume that is the unused fuel return. If my reading is correct then last year these two hoses were fitted incorrectly i.e. the fuel return entered the tank at the outlet valve and the fuel feed left from the fuel return connection on the tank on its way to the primary filter. The engine worked fine all year even when there was only about 10 litres in the tank.
So, should it have worked and what are the implications?
Thanks in anticipation of authoratative, helpful replies!
