Fuel purification
SailingDoc
Active Member
4 Jan 2003
Portsmouth UK
Apologies if there have been recent threads on this - the search engine is playing up.
I'm interested to know if anyone out there has tried the Dieselcraft fuel purification system - as seen at the So'ton Boat Show. Consists of a separator tank and/or a 'stabiliser' which seems to 'induce a small electrical charge' into the fuel. No filters involved - though one would be daft to actually omit the primary filter. Sounds a little too good to be true, but if it can actually disperse the diesel-bug sludge and take it out of circulation, then maybe it'd be worth considering.
Brian
You know the old saying...
Sounds a little too good to be true....
[/ QUOTE ]You know the old saying, don't you?
G'day Brian,
This system will replace your filters but will extend their life. However they are based on 1 inch fuel lines and designed for for over 300 US Gallons per hour.
Comprising 2 components, the first is a centrifuge to remove water and larger particles as used on many commercial vessels almost all navy ships.
The second part is a Strontium Magnet, this is thought to improve flow and filtration by using magnetics to align particles, the evidence for this can be a bit confusing depending on the source.
Hope this helps.
Avagoodweekend......
The Dieselcraft range covers all sizes from 1/4" (5-29 GPH) upwards, so it would suit almost any craft. Question is, can anyone out there vouch that the magnet actually does anything (useful) ?
Brian
