Fuel pipe
7 Jan 2007
Hi I need to replace a short piece of pipe from the tank to the cav filter, it's around a metre long. The take off is at the top of the tank. How can I fill the pipe with fuel, do I just bleed the system on the cav filter. Tia.
RivalRedwing
9 Nov 2004
Rochester, UK, boat in SYH
lw395
16 May 2007
There should be a shutoff valve at the tank.
Open valve.
Suck fuel through with a syringe.
Close valve.
repeat as needed.
PaulRainbow
16 May 2016
Suffolk
Would be useful to know what engine you have and what other filters. How do you normally bleed the system when you change filters ?
NormanS
10 Nov 2008
I have a good old fashioned tank, with the takeoff from the bottom, but if I was faced with this problem I would temporarily block the tank breather with a rag, and slightly pressurise the fuel tank with a dinghy pump.
