Airscrew
Hi to all.
Couple of questions.
I am planning to insert a bulb primer in my fuel line. Engine access (MD11) is very limited and bleeding single handed needs both acrobatic and contortionist skills that are dwindling..
Because of the position and routing, I will need to insert a small additional length of rubber hose.
There are two different pipes on either side of the CAV filter, one marked 5/16 (9.5mm) - the brackets are marked on the pipe. The pipe on other side of the CAV is unmarked and the OD looks slightly narrower. From the outside, they both look reinforced.
Q1. Would you put the primer bulb on the tank side, or the engine side of the CAV(primary) filter? Does it matter?
Q2. I was not able to remove the hose from either side of the CAV. Some force and twisting produced only rotation. Is there a knack to getting a hose off a barbed tail? Or do I have to cut it off?
I decided to leave it all intact yesterday and come to this forum before potentially butchering a working system!
Q3. Is the reinforcement likely to be nylon or steel. If I have to cut it, can I use a stanley knife, or will I need a hacksaw (position in situ will make this near impossible)?
Q4. The nearby chandler has 8mm and 10mm fuel hose. Can I mix 10mm and 5/16. ie put 10mm pipe onto the tail what currently has the 5/16 pipe on it?
Q5. Is there any way of telling what tail sizes are already fitted to the CAV - ofcourse before I take them off !
Thanks.
Thanks.
