KenTheCanadian
New Member
Here's the solution for a known problem with the 5 hp (F5BM) Parsun 4-strokes.
The fuel filter inside the internal fuel tank comes loose and blocks the outflow of fuel. It can leave you stranded, as I found out. The motor simply won't start because it can't get fuel.
If you want to know more, there's a service bulletin here:
http://www.mticanada.ca/products/parsun_en.html
Also, there may be damage to the gas valve seal on pre-2009 models if you've used fuel containing ethanol.
I wanted to put this notice up on the Internet in hopes that someone else won't take as long to Google the solution as I did.
Ken
Ken
