Fuel Consumption
that would be a lightweight cat then...............
nothing short of amazing for a conventional planning cruiser - erring on the unbelieviable!
1.1m/pl on a 25ft / 2.5 ton boat is considered excellent
1.3m p/l for a 30ft cruiser would be stunning
however - achieveing 20 knots from 160hp on a 30 ft craft suggests it's got to be a displacement multihull built v v light and a max speed>?
8 stella's an hour?
more seriously with the same engine / drive about the same consumption at the same speed.
couple of people reengined small boats with the 150 TDI mercruser unit and were reporting similar consumption - they also had another 15 knots or so available too.
But this is a 30ft displacement cruiser, not a planing sports boat - with about another 10 knots to go (top speed around 30knots) - baring in mind this is just diesal. With Petrol outboards the figures are not to disimilair.
Something to think about? A sports fisher, weekend cruiser, rivers,ocean, day trips, charter plus an atlantic crossing to come. What with fuel costs going up n'all that, a likely candidate for market leader??
yep a likely market leader
sounds similar to the 8m cat we were suggesting this power / engine config for earlier in the year.
30 knots 30ft and displacement don;t seem to match even for a cat though!
In that case its almost exactly what i would expect the engine to burn based on D3 160 based on 1 gallon per hour per 20hp (which is a common assumption), using the forumula (ok, so its a bit higher - but hard to take into account drive losses, so assumed vp figures for leg)
((((actual revs/rated power revs)^3)*rated power)/20)
this gives us
((((3000/4000)^3)*155)/20) = 3.27 gph.
(assuming 8hp loss in transmission (which volvo penta do))
i am only taking hp at the prop from vp, NOT any fuel figures - i am using the general 20hp per (gallon per hour) rule, which pretty much does work for *most* diesel engines.
