Portofino
I had a slight list since I had the boat to stb .
We have 3 diesel,tanks
2=main 800 L each for an engine connected with a balance pipe cocked at both ends .
There’s also a optional long range tank of 600 L stb to the stb engine cocked at both ends .
Sight glasses on the mains as well as gauges on the dash ( for what use they are )
No guage or sight glass on the LRT .
Tapping the mains and looking at the level in the sight you hear a dull thud below and a hollow sound above .
Tapping the LRT it’s dull thud right up just 10 cm from the top,90 cm tall .
So I think it’s full .
Last time it was used was on the Del trip Nov 14 ?
600 L sat as far outboard as poss probably accounts for the list .
Thing is what do I do with it ?
I have tried to pass a pipe ( various sizes btw ) down the filler to access the LRT contents - it’s only goes as far as the “ deck anti spill device “;
So I though could test it ? With a view to allowing to mix into the stb main , ie open the cocks to let it drain down , it’s a bit higher and relies on gravity to drain .
Managed to pull the connection pipe off ( connects LRT to stb only ) and drain some off .
Last night poured a bottle of Startron in - reckons to disperse water etc .
Here’s the results 6 hrs or so later - small bottle is the pipe contents initially, large the next 2 L
It’s yellow but not cloudy or zero black specs / bugs etc
https://imgur.com/a/gKr0d3v
