Which direction should the vertical handle rotate, towards A or B?
Also, any advice on how to free up a frozen seacock? Not sure if it froze from corrosion, or pushed too hard in the wrong direction, or a combination.
Calcium deposits internally seem to be the worst cause of siezing. Is it a heads outlet?
with detents its the direction the valve was fitted.
It's usually the heads outlet where the calcium builds up.
If you can reach the ball with a long screwdriver when the boat is on the hard you might be able to scrape or knock away enough calcium to be able to turn it. Also safer to use brute force when out of the water.
I replaced one last year (had to replace the skin fitting too). Frustrating as the old one was perfect apart from the calcium deposits, but it was impossible to reach, so no alternative.
Yes, we will fiddle with it next time it's hauled.
Can you tell from the photo which direction we should "ease" the handle?
As a general rule. righty tighty lefty loosy works.
In line open, across closed.
Most ball valves have a little tab on the 180 opposite side of the handle. which comes up against a stop on the main casing after rotating 90 deg clockwise.
In an awkward spot where you can't see, feel with your finger..
To free it I would suggest.
direct heat to casing with a heat gun.
The casing should heat up faster and expand more than the ball.
A couple of good sharp taps with a hammer on casing. right around it. and directly on the end of the spindle(not the handle).
The handles on the valves are sometimes not very robust so be careful if trying a pipe or hammering the handle.
If you do wreck the handle some can still be removed and a cresent wrench of the right sise
may still work.
once you get it to move. open and close every now and then
Personally I would plug the skin fitting with a suitable piece of wood or plastic and fill the valve with dilute hydrochloric acid, bought as brick cleaner from a wide variety of suppliers, e.g. B&Q. Make sure it is HCL as some are not. It will only take five minutes for all the calcium deposits to be dissolved.
From the first day on the job as an apprentice. If there is a handle, it is open when in line with the pipe, closed at right angles to the pipe. ALWAYS turn clockwise, looking at the handle, to close. Anticlockwise to open. If opening a wheel handled valve, open fully, then close half a turn. This is so the wheel is loose, signifying that it is open. If someone opens it fully against the stop then it can feel fully shut and people could damage it trying to open it further.Which direction should the vertical handle rotate, towards A or B?
