Frost free boats
paulskent
24 May 2004
Deganwy Wales
This is my first winter with a new boat....
I have been looking at the options for ensuring that my pride and joy doesn't freeze up over the winter. It will be on a marina with shore power available.
I have seen that some companies offer a
DIMPLEX COLD WATCHER
Anybody any experience of these or similar devices. Or any other suggestions.
fireball
15 Nov 2004
Wouldn't it be easier to put a small domestic electric heater on board possibly attached via a timer?
paulskent
24 May 2004
Deganwy Wales
I think that is exactly what the Dimplex unit is.. Except it has a thermostat rather than a timer so it only turns on when it gets very cold...
Or at least thats what I think it does.
fireball
15 Nov 2004
most domestic fan/radiator heaters have a thermostat too ... very few have a timer.
It will just heat up the damp though so would need to watch for humidity ...
10 Sep 2004
Christchurch UK
Use a dehumidifier with the drain over the sink. They give off sufficient heat to stop freezing (unless your boat is gigantic) and not surprisingly keep things crispy-dry
Geoff
fireball
15 Nov 2004
I bought the £80 quid one from Argos - works down to 5degrees so don't know if it will stop the frost when it gets really cold....
Will let you know how it is going when I check it for the first time tomorrow!
AliM
24 Jun 2004
UK, Herts/Essex
I suspect damp is more of a problem than freezing.
We bought a Homebase special offer standard dehumidifier last year. It carried on working even when the deck was covered with frost or snow. It kept everything dry and pumped out enough heat to prevent anything freezing. We had a small electric heater, which we used just when we were there.
robp
Some dehumidifiers will stop working at low temperatures (around 5 degrees). Which is why some have built in de-frost. I use tubular greenhouse heaters in conjunction. They are cheap n safe. I lay one next to the engine and one or two in the saloon/up front. All on timers.
EdEssery
5 Sep 2001
Berks.
B&Q Dehumidifier draining into sink combined with the Dimplex heater you propose is what I have used for the past three years - works a treat
ralf1
20 Jan 2004
southern ireland
i use a similar set up no probs the coldwatcher is a very good safe heater designed for this purpose i use two 500w ones on a timer,one in engine bay with floor lifted one in bow area, all internal doors open and windows closed.
