Frigoboat keel cooler grounding
affinite
2 Feb 2005
Eastern Med
I recently installed a Frigoboat keel cooler. The installation instructions said to connect the grounding connector on the KC to battery -ve which I duly did.
The other anode on the hull, the engine, P bracket and rudder are NOT connected to battery -ve but simply interconnected
(The engine (Perkins Prima M60 is isolated from battery -ve)
Does this sound correct?
The reason I ask is that the anodes on the KC were depleted and there was some strange psychedelic patters on the prop when I hauled the boat out after only 4 weeks in the water
