Mr Cassandra
I need a new 12 volt fridge ,one preferably with easy fit connectors ,however, looking on line at various items the ends from compressed and from plate look large diameters , does anyone have an idea how large?
[t/QUOTE]
Sorry! I haven't the slightest idea what you are talking about.
Maybe someone else can help you?
Just measured mine, 25 mm across flats for the female and 17mm across flats for the smaller male that screws in to it. Add a couple of mm for the across points of flats!try again I have a boat with both a fridge and a separate freezer built in to t galley .The freezer works of a frego pump on the engine.
The fridge works off a 12 v compressor, my wife when defrosting the plate ,put a knife through it.
As the unit is 15 years old, I thought change it for one that is pre charged with easy fit connectors ( no need to get a fridge engineer).,Its the size of the connections I need to know as the access holes on the original are only 10 mm
For info, not arguing, mine is now 20 years old, no leaks, I checked the gas pressures about two years ago. Frost line on evaporator good.I would avoid using instant connectors on a fridge. As they mate a small quantity of air can enter, and invariably they will leak, albeit slowly.
Installed 2008, frogo boat from Penguin. Still working well without any recharge in greeceI would avoid using instant connectors on a fridge. As they mate a small quantity of air can enter, and invariably they will leak, albeit slowly.
