Yngmar
My boat came with a fridge that had a drain hole in one corner, with a small diameter hose connected to it that ended in the bilge. It was a great way to add funky smells and yucky water complete with fridge crumbs and whatnot into an otherwise clean and dry bilge.
As I was fiddling around with the fridge today anyways, I solved this issue:
I zip-tied a loop in the hose (to create a water lock so there's no air exchange with the inside of the fridge) and then cut it off and pulled the yucky end out of the bilge. The remaining hose goes into a small bucket with a hose-sized hole drilled in the lid. Contains the water and smell and is easily removed for emptying, although as the rate at which it dribbled into the bilge was just enough to be annoying it probably lasts quite some time.
Only downside, someone had to eat a bucket full of meringue. Oh, and I have to clean the yuck out of the bilge one last time.
