Tim Good
Whilst accessing the base of a chain plate on the deck I had to remove some cabinets that exposed the top of my fridge. In there is high density foam as you can see. Since I’ve removed all of this do you think it would be a good idea to replace it with a more modern alternative? Perhaps like super quilt the foil back?
Presumably the top of the fridge is less important to insulates than the bottom? Presumably the cold air sinks to the bottom and therefore dissipates out of the fridge more easily from the bottom?
