Fridge foam insulation sheets in Lanzarote
MrMan
New Member
28 Feb 2019
sailingmowzer.co.uk
One of the jobs we didn't get round to in the UK and now realise we should have, was improving the insulation on our fridge. Has anyone ever bought any insulation sheets, like Kingspan, in Lanzarote? A long shot I know but thought I would try. We are in Rubicon marina Playa Blanca so ideally somewhere close to there but suspect it will probably have to be Arrecife.
I dunno many if any big hardware shops in Playa Blance but then there are others hereabouts who might.... Otherwise Yes, there's a massive hardware shop or two around Arrecife... one I wd try for only-slightly-boaty materials is on Calle Miguel Herndez called something like PT (name escapes me) but it's opposite the northern end of the road with MacDonalds and Decathlon on it. Utterly huge place, bit fancy from the front with exhibition area but monster DIY stuff at the back . From Playa Blanca, head into Arrecife on the LZ2, turn right off to take the circumvalacion LZ3, then first main turn-off north LZ20 so up to to the roundabout, take the 3rd = 9oclock turning from that roundabout, then first right off that 400yds filter off right past the front of Repsol garage, then get in lane to turn right at the t-junction and 200yds down there on the left.
Suggestion. Before traipsing off to Arecife, there are three hardware stores on the outskirts of Playa Blanca. FT, Sumenistros, and the one I would try first, Ferrocur. That's the one with the cement mixers outside. Ten minute walk from the bus station...but uphill.
How about spray insulation stuff? Mebbe got that.
If you want, send me a PM. I live in Playa Blanca, have a boat in Rubicon and know a man who will know!
Thank you, I have tried the three hardware stores just on from the petrol station in playa Blanca and they don’t have the sheets. I have some spray foam which I’ll use but I also want to line the inside to make it smaller and improve the insulation.
Thanks for the help though, I’ll let you know how I get on.
Thanks, heading there today so will check it out.
