asteven221
Is it just us that find when we use the boat all the time nothing seems to stop working and as soon as we leave the boat for a couple of weeks and nip down to the marina to check all is ok, some item decides to break itself?
It's the fridge this time. It's made by Engel and works on 240v and 12v, auto switching from one to the other as required. All of a sudden it's decided that it won't switch off using the internal slide switch. At this point I have switched off the 12v breaker on the main panel. If I then switch the internal slide switch too off as normal when leaving the boat, it appears to keep running and the compressor motor (I think that's the noise!) then starts to sound as if it's rapidly switching on/off like it a loose connection. It won't stop making that noise until I kill the 240v at the mains switch. The noise is quite severe.
Has anyone seen this fault and can advise, before I start to do some fridge surgery?
Thanks.
Thanks.
