dgadee
I brought lines back to the cockpit (30 footer with a 13m mast) and it's very, very difficult to raise the main now. It isn't fully battened. I replaced the mast base block with a larger ball bearing one which helped a little bit. The line comes to the base block, out at 90 degrees and then turns (not too sharply) through two Spinlock deck organisers and thence back to the winch.
Although hard to raise, the sail comes down with little problem. The track has been flooded with lubricant.
What do you think? Winch too small? Tides marine insert? Different slides? Thinner new technology rope?
I was out yesterday and took a drill and winch bit with me. Drill was 65 Nm but it only got the main up 2/3rds of the way. Would prefer a solution that doesn't involve buying an e-winch thing.
