demonboy
A couple of months ago I posted a thread about my prop going into freewheel when in high revs. Possible solutions from the responses I received ranged from cavitation to the shear pin.
I chickened out in the end and took the OB to a mechanic here in Turkey and explained the problem, ney, demonstrated it to him, telling him it was a prop issue. So he stripped the entire engine, air-blasted every component of the carb, oil change etc - basically a whole service which I didn't ask for (and I won't be paying for it either) - and then told me the problem was solved! I asked him to show me and sure enough, the problem was still there. So he took the prop off, took a cursory glance at it and told me the problem was the prop! Like I hadn't just told you that! Why you no listen? True Turkish stylee.
Anyway, he showed me that the impeller-type grommet thing that holds the teethed nut in place in the centre of the prop was slipping (apologies for non-technical jargon), which makes complete sense. Stick a screw-driver in it and you can forcefully turn the inside of the prop.
However he claims that this requires an entire new prop. Surely I can just replace this centre bit of the prop rather than buying a whole new one?
Any clues?
Hope this helps start to clear up the mystery of an issue that a lot of you guys were very helpful with. Watch this space......
Any clues?
