Freeview reception on board
Nickcf
13 Apr 2004
Kent
Anyone got any advice on which (if any!) are best aerials for reception of digital freeview on my mobo? I've got a Sony freeview box i can use. Currently use the existing UHF (round thing- can't remember the make) but's it's about as much use as a chocolate teapot.
Talbot
23 Aug 2003
Brighton, UK
You can get different versions of the Glomex (flying saucer thingy) even from the same manufacturer - the normal one is marginal with digital, but you can get much better ones (at much higher prices ) which amplify the signal much further, and thus work better.
Nickcf
13 Apr 2004
Kent
Many thanks for the info guys, I will be using it along south coast (Brighton to Torquay. The existing coax is the original (10yrs old now) so I'll rewire as well.
nick
Planty
2 May 2003
West Midlands
Had exactly the same problem. Glomex and that other one thats even more expensive are useless we've found with Freeview. However 19.99 internal aerial frome Maplins, the one with the circular band, 2 x extending stick aerials and a built in booster is fantastic. Needs a long coaxial cable on it though as you have to trail about a bit to get best reception. On our boat on the "dashboard" front of inside helm position seems to work really well in most places, even in Poole. Have it fixed up to a Philips freeview box which has an aerial siting function on it that shows strength & quality of signal. Channels 23 & 28 are the ones for all the mainstream channels plus loads of others. Paul
SpiderDiver
27 Aug 2004
South Coast
Installed a Triax UFO aerial (omni) from www.cpc.co.uk and use this with Sony Freeview for excellent pictures in Torquay marina. Even at low tide no sound or audio break-ups/freezing. Comes with it's own amplifier but used original aerial's downlead.
