France bottled gas
fisherman
2 Dec 2005
Far S. Cornwall
looking at gas for a campervan, seems the French don't do a small 6kg or so bottle with screw compression connector, just snap on. How do you lot get on for Calor or similar when abroad? I have to source fittings and regulator that will be easy to use, copper pipe from stove to gas compartment, jubilee clipped hose is a nono.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Gaslow bottle for Autogas. My bottle is 13 kg but I believe they do a 6 kg. Initial outlay will soon be recovered in the low cost of Autogas compared with bottled. And you can use it anywhere across Europe with a couple of cheap adaptors.
VicS
13 Jul 2002
The range of adapters from Will Hayward might help you .... Rats ... flashy new website.
https://www.whayward.shop/cylinder-adaptors
https://www.whayward.shop/adaptor-compatability
Worm drive clips are acceptable on low pressure hoses .... I don't like them on hoses that small ...... but their purpose should only be to stop the hose pulling off ... it should be gas tight without the clip.
I prefer Min hose clips for things that need regularly disconnecting / reconnecting
https://www.westfieldfasteners.co.u...MItayk_Pip4AIV4jLTCh137Aw_EAAYBCAAEgLUIPD_BwE
"Ear clips", or similar crimped clamps, are required for high pressure hoses.
