forward/reverse
michaelf1
14 Jun 2007
i have the usual (bmw marine) forward/reverse lever with a pin to push in for neutral. The pin is not popping out as it should. i have tried lubricants, and access from the inside is not straightforward - any suggestions for a remedy please?
alec
16 Sep 2003
East Coast
Good question. I would like to know as well.
At the moment, I tap it lightly with a hammer from the other side.
Good tool the old hammer.
ShipsWoofy
10 Sep 2004
Not that I have had a problem with mine, but I would imagine there is a spring under compression that has somehow dislodged or is too weak. Does this mean you can't get her into gear, if the shift is going into gear then something has snapped rather than the button not popping up, if you see my thinking.
pvb
UK East Coast
The neutral button on my Volvo lever got very sticky. I sprayed quite a lot of "dry lube" lubricant into it, and a lot of muck came out. Problem didn't entirely go away, and I realised the red plastic moulded cover on the button had degraded with UV so I removed it, leaving just the brass button. Works fine now.
MoodySabre
24 Oct 2006
Bradwell and Leigh-on-Sea
I recall reading an article in either PBO or ST in the past year or so (that copy no longer held) of how to strip down the lever and replace the spring. It was a long and complicated task done on a bench as the lever isn't designed to come apart. I'm fairly practical but I thought that I'd rather buy a new one! My previous boat had a new lever that was easy to take apart and get to the spring from the front. Older ones seem not to be built with repairs in mind.
Birdseye
9 Mar 2003
s e wales
Not often you hear it that way round!
tobble
4 Oct 2005
Cardiff
ditto with my Yanmar
wiggy
13 Jun 2001
Portsmouth Harbour
Just sorted mine out after 4 years of faffing around, culminated with awkward situation when engine would not come out of neutral. I sorted it by spraying nearly a whole can of WD40 from the front into the button, whilst pushing it in and out, at first it made no difference at all but I just kept spraying and after a while lots of rusty muck came out with lots of particulates. I kept going untill run off was clear, its now like new.
alec
16 Sep 2003
East Coast
Amazing !
Just done the very same thing myself today. Have used loads of WD40 but still getting loads of 'rusty muck'. Where is it all coming from in such a small space ? .
Will carry on tomorrow but it's popping out fine already.
michaelf1
14 Jun 2007
thanks for your responses. copious amounts of wd40 pushed out some rusty muck, and its currently performing sweetly. i wish id invented that wd40 stuff...
