snowleopard
i need to know how i can work out how much tension is required in a forestay to achieve a given degree of sag in the forestay, given area, wind speed etc.
my problem is that with a flexible unstayed mast i have to load the jib luff dynamically so that it sets with the correct degree of sag so i'm trying to devise a spring mechanism but need to work out the loadings on it.
does anyone know where i can find a suitable formula? also, from a practical point of view, if you have an adjustable backstay, how much pressure do you put on it, say in 15 knots apparent and what are your i & j measurements?
