Tam Lin
I had to replace the bow roller on my Centaur as it was cracked. I chose to put on a double roller and also had the boat’s rigging replaced. The problem is that the forestay toggle is rather large and along with the clevis pin takes up a lot of space making it difficult to use one of the rollers. As the boat sits on a swinging mooring the bow roller is in regular use.
I had thought of disconnecting the toggle and putting it in a vice to squeeze it shut then using a shorter clevis pin, or I could replace it with a thinner one.
A well respected sailor told me that there should be some slack to allow for movement. I did an Internet search and found some support for this but also advice to pack it tightly with washers to restrict movement.
What does the panel think is the best way to create some space over the second bow roller?
