stamfordian
Hi, all
I am currently starting a project ,boat which has had its original outdrive taken off and a Ford 2.5 diesel engine fitted to take shaft drive.As i want to use her(23ft colvic sports fisher) on a drying mooring,i wish to convert her back to stern drive.
I have been offered a mercruiser 0 drive and wondered where i could buy the drive plate which bolts onto the flywheel and slots onto the splined shaft of the outdrive??.
The engine is fully marinized and fitted with a "round gearbox" i am assuming this is hydrolic as it has an oil cooler fitted.
q: What will i need apart from the drive plate to marry the two up??ie do i need a bell housing to bolt the starter motor to??.
q:sorry to ramble on but the mercruser leg comes with its own water pump...should i use this or the on on the engine...or both??.
Thats it i,ve done for know!! as you can tell new to marine inboards so any help much apprieated
regards.
T.b.
regards.
T.b.
