Did you know that the pressure change in the atmosphere is about 1mb per 30 ft of altitude. So a pressure of 948 (I saw 944 on one synoptic this morning) is equivalent to being at an altidude of 2160 feet on an average (1020 mb in the UK) day!
Nah ... Tape's last krapp (Tape is the black labrador belonging to Mrs Beryl Winston a local B&B landlandy sadly widowed in the 70's with a penchant for sherry and Mr Bell the local campanologist vicar)
i've seen a few references to 'hurricane force 12' in shipping forecasts this winter. what term do they use if there are higher winds i wonder?
i had a nasty shock once when i picked up a weather fax of forecast winds in the atlantic without noticing it was for 500mb altitude. the wind arrows had the usual feathers (i per 10 knots) plus little triangles representing 50 knots - it was the jet stream.
EGPM = Scatsa Airfield, Shetlands (ICAO Designator)
111250Z = Date 11th at 1250Z
15018KT = Wind 150 deg at 19 kts
9999 = Better than 9999 metres visibility (they don't care if more)
FEW008 = a few clouds at 800 feet
BKN018 = Broken cloud layer at 1800 feet
08/06 = Temperature 8 deg C, Dewpoint 6 deg C (If temp=dewpoint, fog results)
Q0993 = QNH is 993 mb (local pressure corrected to sea level)
NOSIG = No significant weather.
A bit terse but you get used to it. Have a look here
1020mb is, I think, equivalent to about 30ft of water. So if it gets down to 944 does that mean that the sea will be raised by 2ft 3ins under the centre of the depression. Are we in for a bit of a storm surge in the North Sea?
