Folding Transom Rib
Hi Magnum,
Congrats on the P43.
If the above is intended for the P43 have a think about its use. You will find most of the CI anchorages Chausey, Minqs, Sark Herm etc require a tender / engine that can be carried by 2 people easily.
Otherwise you may limit your dining options or get stranded ashore waiting for the tender to refloat.
Regards
Karl
Fair point Karl but ideally I'm looking at something as light as possible, probably without a console and almost certainly with a Tohatsu 2-stroke. That should make it easy to drag at least.
I like it. I wonder if you could tilt the tender on snap davits with the engine stowed?
Answering my own question, if the outboard is folded flat to the port side of the tender then when the tender is raised on snap davits the engine will be lying in the correct orientation I think (on its front with leg horizontal).
Irrelevant for Magnum but perhaps of interest to others?
A question for you Dan. Can you launch the RIB with the engine in the stored position? There are photos on the Aermarine site showing exactly that, but surely with the centre part of the transom folded water would flood the boat?
Yes, you can fold the transom on the water.
Here's a video of the 360
And here are a few photos of the smaller model
I own a folding transom are marine rib, it is ace,
No you can't put it on snap davits with engine stowed, too heavy
No it dies not take water in when launching with outboard stowed
Yes it's frustrating that it has taken all these years for people to build something so simple
Yes I would buy one again in a heartbeat and if you do get a yamaha engine , best of the bunch
Good to hear that you like them. Regarding engines at this end of the market, in my opinion nothing beats the simplicity, reliability and light weight of the Tohatsu 2-stroke.
Yamaha make nice engines but remember their spare parts supply chain is awful imho. Sure, you can get an oil filter from stock but non consumables are distributed slowly from a distribution centre in Benelux and they are very good at missing their own quoted delivery date and thereby spoiling your holiday. I'd vote Tohatsu 2 stroke every time for a small egg whisk type outboard
Our experience with Yamaha parts supplies is usually very good. Only recently have we had issues, thanks to the port closures!
